January 20, 2018, 13:08 |
Finer mesh gets worse quality
Vincenzo
Rep Power: 9 |
Hello everyone,
I have found a problem when doing a finer mesh in ICEM. I want to get a Y+ of 30 in my simulation, so I calculated the necessary Y of the first cell and I got a Y=0,000003 m. Al rigth, I went to ICEM and used my previous mesh and set the spacing of 0,000003 in Z direction (of the flow) and I proceed to create the mesh. When I check the Quality criteria on ICEM, I found that I went from 0,7765 to 0,345. So I deciden to check the elements with poor quality and I realize they have some skewness in them, near the center of the O-grid. I try to fix it by aligning the vertex of the block in the same position of Z (beacuse the skewness appears in the Z direction) but it didn't do anything, still I get the same result. One way I try to fix it it was to create a 100 times bigger geometry and scale in FLUENT the resulting mesh with a bigger spacing of nodes to see if the vertices of the mesh remains aligned. But it didnt work, the quality in Fluent dropped once I scaled. So, any ideas why this happens and how to fix it? I attached some captures so you could see the skewness of the cells. Thanks! |
January 21, 2018, 01:36 |
Tamil Nadu
Rep Power: 9 |
Could you share your problematic geometry with your blocking picture
why the finer the mesh the worse the results? | Ema40 | Mesh Generation & Pre-Processing | 9 | March 17, 2016 06:21 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
[ICEM] Bad Quality | **Anny** | ANSYS Meshing & Geometry | 7 | May 28, 2015 06:03 |
[Other] Mesh quality | vitorspadetoventurin | OpenFOAM Meshing & Mesh Conversion | 0 | November 28, 2014 19:27 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
