[ICEM] tidal turbine meshing in ICEM inside a water channel
Old   January 11, 2018, 10:53
Question tidal turbine meshing in ICEM inside a water channel
Federico
eeLio is on a distinguished road
Hello everybody,
This is the first time I write in CFD_Online.
I am a PhD student working on tidal energy.
I would like to ask experts using ICEM which is the best strategy to build a structured mesh of a 3D water channel (rectangular cross section) with a tidal turbine (horizontal axis_hub+blade) placed in the middle.
So far I meshed a 120 deg portion of the inner cylinder domain (turbine).
My first question is:
Which is the best way to join this domain with the rest of the water channel?
-Copy and rotate the blocking ?
- Copy rotate and merge the 120deg mesh portion of the turbine?
second question:
Do I need a complete (360 deg) blocking of the turbine to join the inner domain of the water channel?(Supposing I use a create sub-topo under topology and blocking the water channel geometry separately)
Hope you can help me!
Thanks
eElio
eeLio is offline   Reply With Quote
icem, icem blocking, tidal turbine, turbine, wind turbine
Water turbine CFD modeling Peter Main CFD Forum 7 April 4, 2016 03:31
[ANSYS Meshing] Issues in exporting mesh from Meshing to ICEM CFD sihaqqi ANSYS Meshing & Geometry 5 March 5, 2013 03:40
[ICEM] Meshing adjacent wall geometry and simple ICEM questions everdimension ANSYS Meshing & Geometry 25 June 20, 2012 05:25
Q: how to do a good meshing in turbine usin gambit oscar FLOW-3D 1 March 15, 2009 00:15
Missing tets along line when meshing with ICEM CFD Georges P. Côté CFX 6 March 23, 2006 01:34
