[DesignModeler] is it possible to create an interface inside closed-loop geometry?
Old   December 29, 2017, 17:31
Default is it possible to create an interface inside closed-loop geometry?
s1291's Avatar
s1291 is on a distinguished road
I am trying to simulate closed-loop wind tunnel in 2D. I want to model the fan as "Fan boundary condition". According to Ansys documentation the Fan must be modeled must be modeled as the interface between cells http://www.afs.enea.it/project/neptu...ug/node254.htm.
AFAIK, in Design Modeler I can only create two surfaces, and specify the second surface as a Fan zone, then I have to change it to interior in Fluent (but in this case I have two interfaces).
Can you tell me how can I create the geometry with only one interface as illustrated in the image below?
Thank you
https://ibb.co/d53vgb
"When in doubt, use brute force." -- Ken Thompson
s1291 is offline   Reply With Quote
design modeler, geometry fluent
[snappyHexMesh] snappyHexMesh can't create refimenet region clktp OpenFOAM Meshing & Mesh Conversion 3 February 27, 2022 10:26
zone-surface: cannot create surface from sliding interface zone. Creating empty surfa sihaqqi FLUENT 0 December 28, 2013 06:27
[blockMesh] Include list of points Hikachu OpenFOAM Meshing & Mesh Conversion 0 June 20, 2011 10:03
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
meshing F1 front wing Steve FLUENT 0 April 17, 2003 13:37
