[ICEM] Problem Meshing Asymmetrical Geometry
Old   December 23, 2017, 06:47
Default Problem Meshing Asymmetrical Geometry
Prathamesh Phadke
Madhatter92 is on a distinguished road
I am having trouble meshing one of my geometry. I went through all the tutorials for hexa meshing. I am still not able to figure out how to mesh this geometry. The geometry is of an experimental setup whose performance I am trying to predict. The geometry consists of three solids: foil, laser zone and paste as shown in Figure 1. Figure 2 shows the same geometry with solid fill.
Following the tutorials I did some initial blocking by creating a 3D bounding box and splitting and deleting unwanted blocks. The final blocking is as shown in Figure 3.
I associated the edges of the blocks with corresponding curves and snapped the vertices. Figure 4 shows the situation after snapping vertices.
I set the part mesh parameters as shown in Figure 5.
The resulting Pre-Mesh was as shown in Figure 6. The meshing is very ugly. The Quality of Pre-mesh is shown in Figure 7.
I want to have mesh as shown in Figure 8. I have attached my geometry file with the post. Can anyone suggest how should I proceed to mesh the geometry? Thanks!
Madhatter92 is offline   Reply With Quote
Old   December 23, 2017, 06:56
Prathamesh Phadke
New post for attachments
Airfoil simulation - Divergence of the results - Mesh or geometry problem ? Pol.P FLUENT 9 March 7, 2022 18:21
[ICEM] Icem meshing problem in T junction geometry Abdullahkhan0070 ANSYS Meshing & Geometry 2 November 27, 2017 12:16
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 11:49
[Gmsh] Problem meshing an imported geometry Alicia OpenFOAM Meshing & Mesh Conversion 0 March 30, 2010 05:53
Problem meshing turb. blade tip clearance geometry Balu FLUENT 0 June 7, 2008 22:10
