December 15, 2017, 09:08 |
Tip Clearance Unequally Spaced
M
Rep Power: 12 |
I have an issue with the geometric respresentation and meshing by turbogrid. See attached two images of my blade's tip geometry. I tried to apply an identical clearance with two methods: A) Normal Distance and B) Profile Number (which I specified in DesignModeler). While you can clearly see how B has a constant clearance height, A's shape looks strange in the region before the trailing edge. I already tried setting shroud representation to piece-wise linear. As I want to apply the clearance as an actual value rather than span, I would like to use method A and have to resolve this. Any suggestions on how to fix this? Thank you in advance. |
tip shroud, turbogrid |
Out File does not show Imbalance in % | Mmaragann | CFX | 5 | January 20, 2017 10:20 |
[ICEM] Turbine blade with filleting and tip clearance | Pursuor | ANSYS Meshing & Geometry | 4 | July 7, 2010 13:56 |
Meshing in tip clearance. | me | Siemens | 0 | August 25, 2008 03:20 |
Tip Clearance | Liam | CFX | 3 | September 7, 2005 05:30 |
Tip Clearance | Drona | CFX | 0 | October 17, 2002 05:25 |
