[Other] Extrude areas in Ansys Mechanical APDL
Old   December 9, 2017, 18:30
Default Extrude areas in Ansys Mechanical APDL
dimitris
dimpapath is on a distinguished road
Hello to everyone.
can someone please help me with a question in Ansys?
I am student and i am working in mechanical APDL. So, i would like to connect these 3 models (airfoils, see attached foto) as a single volume.
I am trying to design a blade with different scale along it. I have already design the airfoils with the specific scales and i can't connect them in order to make my blade model.
I think that extrude command will be a solution but i don't know how i can connect the different airfoils.
Any idea?
Thank you in advance
dimpapath is offline   Reply With Quote
Old   December 15, 2017, 17:35
Gweher's Avatar
Gwenael H.
Gweher will become famous soon enough
Hi Dimitris,
This an easy thing to do with any CAD software, like a 1 button click in Ansys Spaceclaim using blend option.
But if you want to do it in APDL, you have to adopt a bottom-up approach. I would recommend to create guide curves between the 3 different leading edges points and trailing edges points. Once you have those guide curves you can use the “VDRAG” command to create a volume.
Have fun
Gweher is offline   Reply With Quote
Old   December 18, 2017, 04:56
dimitris
Originally Posted by Gweher View Post
Hi Dimitris,
Have fun
Thank you for your response.
I know that i easily can face this kind of problem in a CAD programm but i must to design my model in APDL.
I didn't try your proposal because i used the command "L, keypoint1, keypoint2" to design lines between two keypoints. So, in a .txt file i wrote the specific keypoints and i designed the lines. I found this as an easily way to draw areas after the lines and a volume after all.
The problem at this time is that i can't design areas according the lines even if i found the command "AL" which is used for this condition. The error "lines not listed for AL command" appears and for the time i can't overpasss it.
Ansys SIG$ILL error loth ANSYS 3 December 24, 2015 06:31
Ansys Mechanical APDL Training... Salam-H Structural Mechanics 0 October 6, 2015 20:54
How to mesh a solid/ shell hemisphere , hexdominant in ansys apdl nishantsinghbme Structural Mechanics 0 September 8, 2014 08:16
Re: Transient Thermal module in Mechanical APDL in ANSYS yashganatra ANSYS 0 May 31, 2013 02:28
How to check common areas at interfaces in ANSYS venugopals ANSYS Meshing & Geometry 0 April 5, 2010 02:42
