[DesignModeler] Problem with body cut using surface extension!
Old   December 8, 2017, 13:25
Default Problem with body cut using surface extension!
malekan.cfd is on a distinguished road
Dear All,
I want to cut a body using extension of a surface. As you can see in the picture, I need to overlap two edges, so I need to use cut tool.
I don't know if this is possible in Ansys Design modeler or space claim environment. Anybody has any advice?
Regards,
Malekan
malekan.cfd is offline   Reply With Quote
Old   December 15, 2017, 14:30
Gweher's Avatar
Gwenael H.
Gweher will become famous soon enough
Hi Malekan,
You can simply extend the cutting surface using the pull tool in SC. Then use the combine tool to cut the target body with the previously extended surface.
Have fun
Gweher is offline   Reply With Quote
Old   December 18, 2017, 11:44
Default Thanks
Dear Gweher,
Thanks for your comment, It did worked!
Regards,
Old   December 22, 2017, 06:08
Gweher's Avatar
Gwenael H.
Hi Malekan,
Happy it helped. You can also use the imprint face option and then pull the other surface out to slice the material
[ICEM] How to draw a 2D surface to a solid 3D Body NikoLee ANSYS Meshing & Geometry 2 November 8, 2016 10:24
[DesignModeler] Boolean Subtract of a body and a surface KrishnaSandeep ANSYS Meshing & Geometry 2 April 1, 2015 16:55
[ANSYS Meshing] Surface Body Named Selections for OpenFoam slowtype ANSYS Meshing & Geometry 2 April 20, 2011 11:35
Problem with capturing water-spreading for free surface flow devesh.baghel OpenFOAM 2 December 10, 2009 02:21
open channel problem (free surface) Andy Chen FLUENT 4 July 10, 2009 02:20
