[ANSYS Meshing] Improve Meshing
Old   November 25, 2017, 14:25
Default Improve Meshing
Felix Issac Arias Alvarez
farias2014 is on a distinguished road
Ansys is suggesting me do inverse orthogonality quality to improve the meshing. How do i get that? My orthogonality is 0.099 and my skewness is around 0.93 max and 0.2 min. How do i improve the skewness?
I am using tetrahedrons meshing with coarse, curvature, medium for span angle.
farias2014 is offline   Reply With Quote
Old   November 26, 2017, 15:36
Gweher's Avatar
Gwenael H.
Gweher will become famous soon enough
Hi Felix,
Difficult to say without a picture of your domain. But the numbers you mentioned represent a really bad mesh. You should increase the mesh density or use local refinement for problematic areas (with high skewed elements). Play around other mesh option instead of curvature, to proximity, play around with defeaturing options etc. Again a bit difficult to guess without additional pictures/problematic area info.
Best of luck
Gweher is offline   Reply With Quote
Old   December 1, 2017, 14:29
Thanks for the advice. I will try to learn a how to use the refinement. Here is a picture in case some can give more detail feedback.
https://drive.google.com/open?id=1d5...Kx_MuTv1Z_sUvS
https://drive.google.com/open?id=109...vED_uGQyeC7sdr
https://drive.google.com/open?id=1Sa...mg1700r7gU-LGB
Old   December 1, 2017, 14:30
Old   December 5, 2017, 02:59
Gweher's Avatar
Gwenael H.
You should definitively add refinements and inflation option to get your BL right
Improve meshing quality pkladisios CFX 12 September 12, 2015 07:03
[ICEM] How to improve meshing quality snejball91 ANSYS Meshing & Geometry 0 July 16, 2015 15:56
Meshing software comparison Wikie Mesh Generation & Pre-Processing 5 September 29, 2014 07:09
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 06:22
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 12:08
