[ANSYS Meshing] Not so pretty Inflation on a curved surface
Old   November 23, 2017, 03:28
Default Not so pretty Inflation on a curved surface
Eric Lee
kyo022 is on a distinguished road
I'm an undergraduate student, and trying to do some analysis on high-speed trains.
Now, my problem is the inflation doesn't seem so pretty on the curved surfaces like the nose of the train.
I'm not even sure if that's normal for the inflation to become wider as the boundary layer gets curved.
I'd appreciate if you could provide some advice on this.
Thank you.
kyo022 is offline   Reply With Quote
Old   November 23, 2017, 06:11
Gweher's Avatar
Gwenael H.
Gweher will become famous soon enough
Hi Eric,
You need to play with the inflation options (i.e. total thickness option or first layer height). If you want to have more control you can also slice your geometry and add edge sizing with bias for your boundary layer.
Have fun
Gweher is offline   Reply With Quote
Old   November 29, 2017, 03:04
Eric Lee
Thank you so much, Sir.
I think I found a proper setting for my case.
it took some time, but your advice helped me a lot.
Thank you!
Old   November 29, 2017, 08:13
Gweher's Avatar
Gwenael H.
You're welcome Eric, happy it helped.
The next step could be to further improve your meshing with ICEM as you have better control and nice and powerful build in smoothing options.
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 12:12
Inflation/Prism layer for rough surface Dhairya@CFD ANSYS 0 February 23, 2017 01:00
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 16:03
Grid on curved surface Beggin Main CFD Forum 0 October 15, 2003 01:41
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
