[ICEM] Problem with mesh outside of fluid domain |
October 26, 2017, 13:36 |
Bruno Iadocicco
I am doing an analysis of a building in ansys cfx and recently I moved from the ansys mesher to ICEM.
Despite following tutorials and looking up on lectures and posts in this forum, I am having a problem I could not yet solve. The mesher is generating elements outside of the fluid domain. The geometry was made in SpaceClaim, the domain included. Once inside ICEM, I used "build topology" and tried diferent things: 1) fluid and solid bodys, but in this case it created mesh inside the solid also; 2) created only fluid body, but it is creating mesh outside fluid domain; 3) with no body, the mesher create some CREATED_MATERIALS but still with elements outside of fluid domain. All cases I used Octree Mesh Method. geometry.jpg fluid domain.JPG fluid domain with body.JPG mesh outside fluid domain.JPG build topology.JPG |
October 27, 2017, 03:14 |
Stuart
Rep Power: 26 |
Odd, as you said you ran Build Topology first to generate the curves and points, did you alter the options here, see the User Guide.
icem, meshing, solid body |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
Out File does not show Imbalance in % | Mmaragann | CFX | 5 | January 20, 2017 11:20 |
Sudden increase the residual of Maxwell's equations | hsezsz | CFX | 2 | October 13, 2016 07:58 |
[ICEM] Problem making structural mesh on a surface | froztbear | ANSYS Meshing & Geometry | 1 | November 10, 2011 09:52 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
