[DesignModeler] How to merge faces of two concentric spheres.
Old   October 23, 2017, 12:27
Exclamation How to merge faces of two concentric spheres.
Mayuresh Vaze
mayuresh0987 is on a distinguished road
Problem Statement:
I have to perform transient thermal analysis on a spherical flask which has 2 layers of insulation. To simplify the problem I neglected the cap portion of the flask and assumed it to be two whole concentric spheres.
My problem is that for conduction to occur, I would merge the two faces of insulation which are supposed to be in contact with eachother.
But when I try to use the merge feature of Ansys Design Modeller, It shows this error message:
" No valid mergeable clusters"
Pls help me.
mayuresh0987 is offline   Reply With Quote
ansys 13 work bench, designmodeller, workbench ansys 15
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 08:56
Decomposing meshes Tobi OpenFOAM Pre-Processing 22 February 24, 2023 10:23
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 04:21
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 11:58
