[Other] Error Converting .msh file to grd file |
October 17, 2017, 11:54 |
Is there a was to Retrieve the blocking information from a .msh file using ICEM-CFD
October 17, 2017, 15:21 |
Sebastian Engel
Rep Power: 21 |
Hi James,
indeed, there is a way. Go to: File > Blocking > Load from Unstruct mesh This can recover the blocking from a .msh. However, it can take very long or fail for very complex blockings. with regards, Sebastian |
.msh extension file, .msh format, converting error, import error |
how to calculate mass flow rate on patches and summation of that during the run? | immortality | OpenFOAM Post-Processing | 104 | February 16, 2021 08:46 |
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 | towanda | OpenFOAM Community Contributions | 6 | September 5, 2015 21:03 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
