[ICEM] Axial Fan with Housing inside of a Rectangular Duct
Old   October 16, 2017, 06:39
Post Axial Fan with Housing inside of a Rectangular Duct
joygiak
joygiak is on a distinguished road
Hello guys,
I am new in ICEM (started before 2 weeks) and i am working in a project which includes a fan with housing inside of a rectangular duct. Till now, I've managed to make the mesh for the fan and the casing with quality greater than 0.3 and without any problems in check mesh.
My problems are starting when i am trying to make the volume mesh inside of the duct. To make it easier to understand, i will describe the steps that i am doing in logical flow and add pics for some steps.
1) complete the surface mesh for casing and propeller
2) making the duct which surfaces are attached in the casing surfaces
3) run topology so i can split the surfaces of the duct in the region of the casing
4) making the surface mesh for duct (quality is good, only double edge elements in check mesh which is not a problem as i saw in the forum )
5) making the fluid material inside of the duct
6) create volume mesh in fluid part (delaunay) with hexa-core , not prisms yet
7) first problem is that fluid part is going inside of the casing, although I got already a material point for the casing. In the propeller, I don't have this problem. (I think it is caused because of splitting surfaces in the duct)
8) second problem is bad quality volume elements ( didn't make any prism yet or try to fix the quality by smooth globally because of the first problem ). How can i improve them?
If you can suggest me something to solve 7) and 8) step, I would be realy greatfull. Also any ideas for trying something different are welcome. If necessary I can upload the prj file.
Thanks in advance.
pics: https://1drv.ms/f/s!AgHf8Bb9lj7blGkoH72tWjQ9OaDU
joygiak is offline   Reply With Quote
axial fan, icem, improve mesh
How to build current blower fan model in Flotherm eric0722 FloEFD, FloWorks & FloTHERM 3 January 2, 2021 03:36
flux through fan duct Anderl OpenFOAM Programming & Development 0 April 24, 2012 11:26
Turbulence flow in a rectangular duct Watchapon Main CFD Forum 0 April 7, 2007 08:34
2D simulation of circular and rectangular duct mvee FLUENT 4 March 24, 2007 00:40
flow simulation across a small fan jane luo Main CFD Forum 15 April 12, 2004 18:49
