October 9, 2017, 05:16 |
Explicit Dynamics
Prince Hossain
Rep Power: 9 |
I am trying to do a simulation on a punching operation. The solution is taking too much time (4 hours and still half way). My question is, is it obvious for a explicit solver or my settings might be wrong. I am trying on a simple geometry.
TIA |
October 10, 2017, 06:50 |
Stuart
Rep Power: 26 |
This should be posted in the structural analysis section and the question is not well posed.
Explicit dynamics simulations will have (very) small timestep and can require (very) many timesteps. I've had simulations which take days to run. Find where the time step governing mesh element(s) are and fix them (e.g. remesh, mass scaling). ED really should be conducted on simplified geometries to give insight into the problem rather than trying to gain detailed data. Also I find that using 16 CPUs is the most efficient, if I think a model needs more CPU cores I make the model simpler. |
October 10, 2017, 07:21 |
Prince Hossain
Rep Power: 9 |
Thank you for your suggestion.
And nest time i will post in the correct section. |
How to set the correct material datas for composite simulation in Explicit Dynamics i | asuasura | ANSYS | 1 | June 12, 2018 23:20 |
Hyperelastic Material model in Explicit Dynamics | sghod17 | Structural Mechanics | 0 | July 17, 2015 16:07 |
[ANSYS Meshing] Explicit Dynamics "Model" problem with mesh | ATD | ANSYS Meshing & Geometry | 0 | January 24, 2013 08:43 |
Couple between Explicit Dynamics and CFX | Delcraft | ANSYS | 0 | August 13, 2012 11:14 |
Ansys 13.0 Explicit Dynamics Tutorial | WenZyn Lim | ANSYS | 0 | April 15, 2011 09:57 |
