[ANSYS Meshing] URGENT: Mesh keeps failing at certain values within acceptable size range
Old   September 30, 2017, 14:51
Unhappy URGENT: Mesh keeps failing at certain values within acceptable size range
NukeAce is on a distinguished road
Hi
Ive been trying to refine the mesh of element of a plate and tube heat exchanger consisting of two vertical tubes passing through two parallel rectangular horizontal fins with water in the tubes and air between the fins.#
ive done all appropriate named selections and i am using automatic inflation program controlled
fin thickness is 0.15mm
max face size failure occurs at is 0.85
max size 4.333
i get an error message
Mesher failed to finish inflation.
Patch conforming mesh failed because of pyramid mesh intersecting opposite boundary or bad boundary or inflation mesh.
how can i solve this im presenting in two days please help
NukeAce is offline   Reply With Quote
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
engrid -> save as .stl with boundarie codes Zymon enGrid 31 August 29, 2011 13:40
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
