[ICEM] global size factor affect first layer height?
Old   September 18, 2017, 08:45
Default global size factor affect first layer height?
ranjith.b
ranben10 is on a distinguished road
Changing global scale factor in ICEM CFD affect prism first layer height?
I am trying to do grid independence study with prism layers in ICEM cfd. I calculated first layer height 0.01 mm and done simulation for 30 lakhs mesh elements. Now i wanna double the mesh elements so i change the global scale factor from 1 to 2 but still now i want same first layer height 0.01. changing this global size factor affect my first layer height and make it 0.02 or will it remain as 0.01?
If it changes to 0.02 then how can i keep this constant in grid independency study bcause first layer height calculated from y plus calculation this should not change with mesh elements right?
ranben10 is offline   Reply With Quote
Old   September 20, 2017, 04:18
Kushal Puri
Kushal Puri is on a distinguished road
your first layer height will remain same
Kushal Puri is offline   Reply With Quote
[snappyHexMesh] snappyHexMesh Boundary Layer at Corner panpanzhong OpenFOAM Meshing & Mesh Conversion 5 July 3, 2018 06:53
Stuck in a Rut- interDyMFoam! xoitx OpenFOAM Running, Solving & CFD 14 March 25, 2016 08:09
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 15:37
errors Fahad Main CFD Forum 0 March 23, 2004 14:20
