[DesignModeler] Interference problem when cutting domain |
September 13, 2017, 17:04 |
Rep Power: 12 |
Hello everybody,I need to do some CFD analysis of an aircraft model. I need to divide the domain into two parts: a forward and a backward parts. To do this, I would like to generate two grids separately by using Meshing tool and then use the Mesh Interfaces module of Fluent to match the common surface. I preliminary create only one domain and then I try to slice it in order to have two sub-domains. My problem is the following: when the two subdomains are created by slicing the initial domain, it is observable a not perfect correspondence between the border areas (the misalignment is about 2 mm so not negligibile). This fact, also, produces the misalignment of the corresponding grids.
I hope someone help me. Thank you in advance for your availability. Serena |
grid, interface definition |
Problem with entire domain comprised of split hex cells | Arzed23 | Main CFD Forum | 1 | November 8, 2016 00:01 |
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 06:57 |
Monte Carlo Simulation: H-Energy is not convergating & high Incident Radiation | volleyHC | CFX | 5 | April 3, 2016 06:41 |
multiphase in multiple domain problem | cosine | CFX | 2 | January 3, 2010 17:12 |
2d domain problem | Dan Boyle | FLUENT | 2 | March 3, 2003 09:49 |
