Harold Nasawa
Rep Power: 0 ![]() |
i had given a task to work with CFD which is a Flow past a triangular cylinder with apex facing upstream.
i had given the geometry and an step by step example using a cylindrical pipe. the example file can be downloaded and seen here: https://ufile.io/n0k4b i follow that example which can be seen on above link and got stuck with blocking with my actual geometry or task with the blocking part and associate blocking; see my geometry here:https://ufile.io/uqswg and see what i had done so far up till the blocking part can be downloaded and seen here: https://ufile.io/regoy I really need help. Thank you. |
Lane Carasik
Rep Power: 15 ![]() |
What software are you using?
Harold Nasawa
blocking strategy, meshing 3d |
[ICEM] Correct blocking and Ogrid in ICEM | salumi | ANSYS Meshing & Geometry | 3 | November 8, 2016 10:10 |
[ICEM] Problem to load the blocking | biasilveira | ANSYS Meshing & Geometry | 2 | February 24, 2013 22:04 |
[ICEM] Blocking and Symmetry | BrolY | ANSYS Meshing & Geometry | 32 | August 24, 2012 03:13 |
[ANSYS Meshing] blocking 2D planar, problem associate edge to curve | hadrien51 | ANSYS Meshing & Geometry | 10 | February 21, 2012 12:37 |
[ICEM] Blocking strategy | BrolY | ANSYS Meshing & Geometry | 0 | July 22, 2010 04:46 |
