[Workbench] How to import mesh from abaqus into a static analysis in ANSYS |
August 29, 2017, 11:05 |
Rep Power: 9 |
I've got an abaqus mesh input file, where each element has different thickness. I would like to do a static analysis in ANSYS WORKBENCH 14 using the mesh file that I already have. I want to mesh my model with the mesh that I already have coded in a .inp file in abaqus. I want to do it for different geometries. How can I do it for the exact same geometry? And for other geometries? I guess I can populate any geometry with an already done mesh, just the coordinates of the nodes and the element size will change. Am I correct? Thanks in advance, Best regards, AndradeSilva |
September 1, 2017, 10:09 |
Gwenael H.
Rep Power: 20 |
Hi Andrade,
You can import Abaqus input files (*.inp) directly into Ansys Workbench using the FE Modeller tool. Drag and drop it in the WB project, rmb >Add Input Mesh > browse > select Abaqus Input (*.inp). Once selected you can either link it directly to the Analysis model (reuse the mesh directly) or to the Analysis geometry (this will convert the mesh data to geometry data) and you need to remesh it in Ansys. I’m not sure if the feature was already available in V14 but with later versions it works. Have fun |
September 7, 2017, 09:26 |
Rep Power: 9 |
Can you tell me detailed instruction on how to do it? thanks, Silva |
September 19, 2017, 16:32 |
#4 | |
Gwenael H.
Rep Power: 20 |
Well I can’t really detail more the procedure to import the Abaqus input file (.inp) into Ansys for a static structural analysis:
Looking closer at your request regarding the different geometries, you cannot “populate any geometry with an already done mesh”. The mesh is used to discretize your geometry and the mesh is a result of the geometry discretization not the other way around. You can still use tools like RBFmorph for Ansys (add-on tool) to manipulate mesh directly (scale / offset / etc) but it’s rather expensive. So you’ll be better of repeating the previous import procedure for every new geometry having its own mesh. Have fun |
[Other] vtk mesh or Abaqus mesh to OpenFOAM | bigphil | OpenFOAM Meshing & Mesh Conversion | 27 | November 23, 2015 17:31 |
[ANSYS Meshing] export icem cfd mesh to ansys static structural | nauman55 | ANSYS Meshing & Geometry | 3 | July 30, 2014 11:14 |
Import transient cfx-results for static structural analysis in Ansys WB 13 | Colt Seavers | ANSYS | 1 | August 11, 2011 06:01 |
Ansys mesh import problem | sys999 | ANSYS Meshing & Geometry | 4 | January 4, 2011 11:54 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
