[Workbench] odd problem of updating parameter study mesh
Old   August 17, 2017, 12:51
Default odd problem of updating parameter study mesh
funkvps is on a distinguished road
Hello, everyone,
I found a very odd problem of updating a parameter study workbench project, containning geometry and ansys meshing.
The problem is simple, with a parametered geometry and a set of study value.
I found two different philosophy of meshing as below:
1. directly pushing update all designpoint, this will work, however you will only see one ansmeshingserver.exe at any time. My geometry contains multiple sweeptable body.
2. Set any designpoint as current, and rightclick on the designpoint and select update this designpoint. There will be multiple ansmeshingserver.exe to do the meshing job (for the same geometry).
Anyone knows what's the problem? I would like to have the multiple meshing in update all designpoint.
funkvps is offline   Reply With Quote
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
[ICEM] problem in mesh output mehrzad ANSYS Meshing & Geometry 2 December 10, 2014 19:07
Mesh Refinement Study Problem lde5047 Main CFD Forum 3 August 6, 2014 08:22
problem with updating mesh ravitejakatragadda ANSYS Meshing & Geometry 6 February 18, 2011 10:30
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 11:09
