[DesignModeler] Share topology issue
Old   August 14, 2017, 10:14
Unhappy Share topology issue
rohit.nair
rohit.sreekumar is on a distinguished road
i have tried using share topology option for my geometry (axle assembly) . when i keep it in auto mode it does it soon enough. but when i use the imprint option it just goes on. if i try clicking on the window it gets white and shows not responding. while still shows generating feature in the toolbar below. so is it running and my hardware seems weak or its some other issue.? please help me out..
and also how do we obtain node to node connectivity in 3D weld ?
is mesh connection a replacement to share topology.....
rohit.sreekumar is offline   Reply With Quote
design modeler, mesh connection, shared topology
Issue on zeroGradient BC for system rotation magnushaese OpenFOAM Running, Solving & CFD 2 January 28, 2022 14:43
[blockMesh] Internal walls of zero thickness anger OpenFOAM Meshing & Mesh Conversion 23 February 6, 2020 19:25
rhoCentralFoam inviscid airfoil issue (Foam::error::printStack(Foam::Ostream&) at ??) kmkb21 OpenFOAM Running, Solving & CFD 1 March 1, 2018 02:07
foamToTecplot360 issue with multiregion solvers manuc OpenFOAM Post-Processing 2 November 21, 2016 14:51
Meshing related issue in Flow EFD appu FloEFD, FloWorks & FloTHERM 1 May 22, 2011 09:27
