[ICEM] How to cut the surface using curve
Old   August 11, 2017, 13:03
Default How to cut the surface using curve
CFDengineer1
delliganesh07 is on a distinguished road
Send a message via Skype™ to delliganesh07
Dear All,
I am beginner of ICEM. I was using GAMBIT to mesh before. Please go through the attachemnts (2 stl files). The geometry is interface on the woven screen.
Interface is in "filename.stl" and wires in "fibers.stl" .
I want to cut the surfaces in "fibers.stl" using "filename.stl". And delete the part in the lower z-direction(in corodinate axes).
These are things I did:
1) I merged both the stl files
2) Geometry > Create/Modify Surface > Segment/Trim Surface/By angle>selected both the surfaces> Apply
These gave me total five surfaces four wires (green color in screen.jpg) and one interface.
3) Create/Modify Curve/Surface Surface Intersection/Selected two surface (one wire and interface)
This create a curve.
Question: Now I want to trim the screen using the curve in (3)
I the same way as (2) but instead angle > I changed to curve.
But it is not working.
Any kind of help is greatly appreciable.
Thanks,
delliganesh07 is offline   Reply With Quote
icem 17
[ICEM] Controlling growth rate from a curve into a surface granzer ANSYS Meshing & Geometry 3 January 29, 2017 15:43
[Gmsh] 3D coil mesh: can't create the volume? RomainBou OpenFOAM Meshing & Mesh Conversion 3 July 18, 2016 06:09
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
[ICEM] Forcing surface and curve to match sherifkadry ANSYS Meshing & Geometry 0 August 27, 2010 01:28
curve of vortex of free surface in mixing tank bioman66 CFX 1 June 30, 2006 07:19
