August 9, 2017, 10:11 |
Mesh out put format from ICEM-CFD
AGN
Rep Power: 15 |
I'm working on a multi block structured mesh in ICEM-CFD. Once I generated the mesh I will feed that to a FORTRAN code, so I need that mesh in a certain format that should be readable in notepad or similar software. Information that I required from ICEM-CFD is x,y points in the grid followed by nodal information (connectivity matrix) and boundary patch having (x,y) data and (or) nodal information of boundary points. The version I'm using is ansys 13. So that I can write small code that converts the current format into the format that I required. Thank you |
export mesh details, icem 2d blocking |
[Commercial meshers] ICEM mesh file in correct format for OpenFOAM | SamEngD | OpenFOAM Meshing & Mesh Conversion | 0 | April 5, 2017 07:29 |
[ICEM] Problem with volume mesh in ICEM CFD | kolapoasafa | ANSYS Meshing & Geometry | 2 | September 16, 2011 04:54 |
[ICEM] Export unstructured periodic mesh from ICEM CFD to Fluent | ivanddd | ANSYS Meshing & Geometry | 1 | February 3, 2011 01:51 |
How to extrude 2D Mesh in ICEM CFD? | VSB | CFX | 7 | December 27, 2006 12:58 |
importing mesh from ICEM CFD into CFX 5 | Jay | CFX | 2 | November 12, 2002 14:46 |
