August 14, 2017, 08:33 |
#21 |
Sadegh Ebadi
Rep Power: 11 |
Then that's Ok.
I want to be relieved by your checking. How can I send you my file? it's about 21MB. Thanks for your valuable help |
August 14, 2017, 08:40 |
#22 |
Maxime Perelli
Rep Power: 41 |
delete your mesh it will reduce the size
then you will be able to attach it it you thread (I believe)
In memory of my friend Hervé: CFD engineer & freerider |
August 14, 2017, 08:50 |
#23 | |
Sadegh Ebadi
Rep Power: 11 |
CylinderSector.zip It is nice of you to take your time looking at this, Thanks |
August 14, 2017, 08:55 |
#24 |
Maxime Perelli
Rep Power: 41 |
I cannot open it
August 14, 2017, 08:58 |
#25 |
Sadegh Ebadi
Rep Power: 11 |
why?
I have compressed it to reduce it's size. It's a .zip file you should first uncompress it |
August 14, 2017, 09:07 |
#26 |
Maxime Perelli
Rep Power: 41 |
I don't know why
which version do you have?
August 14, 2017, 09:12 |
#27 |
Sadegh Ebadi
Rep Power: 11 |
My gambit is Gambit 2.4!
August 14, 2017, 09:22 |
#28 |
Maxime Perelli
Rep Power: 41 |
weird
you can send the *.jou file
August 14, 2017, 09:26 |
#29 |
Sadegh Ebadi
Rep Power: 11 |
August 14, 2017, 09:45 |
#30 |
Maxime Perelli
Rep Power: 41 |
sending it to my email will not change anything
your journal file is almost empty, so I cannot rebuild your model. Anyway the checkMesh in OF will give tell you if your mesh has good quality (or not)
August 14, 2017, 09:50 |
#31 |
Sadegh Ebadi
Rep Power: 11 |
Ok, thanks I'll do that.
I have another question I want to use cyclic boundary condition in OF for front and back faces but as I see there isn't such a boundary condition in Gambit! what should I do? Also I have attached the right files for .jou and . trn: Gambit.zip |
August 14, 2017, 09:54 |
#32 |
Maxime Perelli
Rep Power: 41 |
I will check it tomorrow (have to go)
For the front and Back Faces, there are plenty of threads on the forum
August 14, 2017, 09:56 |
#33 |
Sadegh Ebadi
Rep Power: 11 |
Ok, thanks for your quick replies dear Maxime.
August 16, 2017, 02:13 |
#34 |
Maxime Perelli
Rep Power: 41 |
I still cannot recreate your model with mesh and BC, but at least I got the geometry.
I could mesh it with hexa, and max skewed element 0.7 I didn't applied any BC, and I remembered you have to link mesh of surfaces which will be assigned to periodic. default_id6528.zip
August 16, 2017, 04:08 |
#35 |
Sadegh Ebadi
Rep Power: 11 |
Hello dear Maxime,
1- I have exported the mesh without axis boundary to openfoam then I run createPatch command to change the FRONT and BACK boundary type to cyclic after this some .obj files were created in the main folder! also a folder named 1e-06. Can you tell me what are these .obj files for? Is there any error that they were created? Here is the image: photo_2017-08-13_13-13-33.jpg 2-I appreciate your time, looking at my case.What are the difference between your file (uploaded) and mine? What are the changes in your file? |
August 16, 2017, 04:36 |
#36 |
Maxime Perelli
Rep Power: 41 |
I only meshed the geometry (without any BC)
Regarding OF, I assume you have one of the newest version. I stopped to work with it for 5 years ago, and I was on version 1.5 So I think it has beed some modifications. So I cannot help you with *.obj. "1e-6 "folder should be the initialization folder, although it was called "0" under version 1.5
August 16, 2017, 04:46 |
#37 |
Sadegh Ebadi
Rep Power: 11 |
Then have you linked mesh of surfaces which will be assigned to cyclic?
Yes I'm using OF 4.1. There is still 0 folder and the 1e-06 is an extra folder that was created after running createPatch, but when I had run createPatch -overwrite command this folder was not created but still .obj files were created! There is a topic in the forum about this subject: createPatch: dumped objects But I can't get the answer to my question, that are these files normal or they had been created due some errors?! |
August 16, 2017, 05:14 |
#38 |
Maxime Perelli
Rep Power: 41 |
No I didn't linked both surface meshes.
I assume that the linking process is only required if you will solve with fluent. I cannot help you with 4.1, since I don't know what new is. I would simply try to run the case. You will quicky see if there is any error
August 16, 2017, 05:37 |
#39 |
Sadegh Ebadi
Rep Power: 11 |
No there isn't any error while running the case
Thanks for your quick replies |
cylinder mesh, gambit, gambit 2.4.6, sector of a cylinder |
Flow past a 2D cylinder - High Re (1E+05) - Cd too high | Pervispasco | OpenFOAM Running, Solving & CFD | 4 | March 14, 2022 03:19 |
Drag force coefficient too high for a flow past a cylinder using komega sst | Scabbard | OpenFOAM Running, Solving & CFD | 37 | March 21, 2016 17:16 |
Forces Acting on a Rotating Cylinder (Moving Mesh) | dreamchaser | CFX | 5 | April 25, 2015 07:01 |
Incorrect Drag and Drag Coefficient for flow over a cylinder | ozzythewise | Main CFD Forum | 8 | June 13, 2012 07:24 |
[blockMesh] Specifying boundary faces failes in blockMesh | blaise | OpenFOAM Meshing & Mesh Conversion | 0 | May 10, 2010 04:56 |
