[ICEM] Urgent Help Needed: Rotate mesh in ICEM |
August 4, 2017, 20:37 |
Vish
Rep Power: 13 |
Hi
I am trying to take advantage of symmetry in my model. I have created mesh in only half of the model. Then I rotate the mesh. I again associate the elements to the parts (Edit Mesh- Repair Mesh- Associate mesh to Geometry)< because I believe this will associate the newly created mesh elements (which Have been created due to rotation of mesh) to the surface parts needed for boundary conditions. After that, I merge meshes on the common part- edit mesh- merge nodes- merge meshes- Select the part (which is called Surf in my model). However, when I import into FLUENT, it shows critical error and aborts. Please help what I may be doing wrong. I need some education in this respect. here is the link to the project files: https://purdue0-my.sharepoint.com/pe...j9HBKTTWahr4qs Last edited by anand32; August 4, 2017 at 20:39. Reason: need to give URL |
August 10, 2017, 00:20 |
#2 | |
Kushal Puri
Rep Power: 12 |
August 10, 2017, 10:43 |
#3 | |
Vish
Rep Power: 13 |
Thank you for your reply. I was able to get over the problem of penetrating elements- import into FLUENT was successful. But I do not know how to use a hexa layer for merging. I am still getting pyramid elements. When you said that I should use a hexa layer to merge instead of pyramid elements, could you please explain how should I execute that? What steps should I follow to merge with hexa layer, instead of the pyramid elements? I am keeping the "Merge Nodes " option OFF while rotating the mesh. Thank you |
August 10, 2017, 11:51 |
#4 | |
Kushal Puri
Rep Power: 12 |
August 10, 2017, 16:27 |
#5 | |
Vish
Rep Power: 13 |
If it is possible to do it that way, then can we not just keep the "Merge Nodes" Option on while copying/mirroring the mesh? Shouldn't that work? It did not work in my case, so I ask. My understanding is that both the methods- the one suggested by you (involving deletion of pyras and extrusion with merging) and the one involving rotating the mesh with merge nodes on will yield the same result. Please advise. Thank you |
August 10, 2017, 23:06 |
#6 | |
Kushal Puri
Rep Power: 12 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Unstructured Mesh ICEM on a cube | jerome_ | ANSYS | 0 | May 30, 2012 05:34 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
URGENT: HELP ICEM beginner mesh generation car | guest7777 | CFX | 13 | October 15, 2007 05:25 |
