August 3, 2017, 20:40 |
Problems after copying blocks
Vish
Rep Power: 13 |
I am trying to mesh a symmetrical geometry. I have created a block in one part of the geometry and then am copying the block by rotation to cover the remaining part.
However, I need your advice regarding two things after copying the blocks: 1. When I copy the block, the new (rotated) block has many entities associated to the old geometry itself. How do I rectify that? Do I need to do the re-assocciation manually or is there a short cut / direct method to do the re-association? 2. Also, there is an error saying there are blocks with same block number and that we should run check/fix. Presumably, the copied and original blocks have the same number. How do I fix that? Will running "check/fix" solve this issue? How do I verify whether the issue is solved? Please advise. Thank you |
August 3, 2017, 20:57 |
Vish
Rep Power: 13 |
Also, when the blocks are rotated and copied across a face, do I have to merge the vertices or nodes on that face? I guess the vertices on that face will also be replicated and so a merging may also be required.
This topic has not been covered in the tutorial and so it is leading to confusion. Please advise. Thank you |
copy blocks, icem |
[Commercial meshers] COnvert FLuent MEsh to openfoam with interface | manuc | OpenFOAM Meshing & Mesh Conversion | 1 | July 25, 2017 03:13 |
[ANSYS Meshing] Periodicity problems in icem | zeeshu | ANSYS Meshing & Geometry | 0 | April 17, 2016 20:59 |
[ICEM] meshing-incomplete mesh in part after moving blocks to separate domains | Mfaizan | ANSYS Meshing & Geometry | 8 | November 29, 2015 21:11 |
[blockMesh] Problems meshing wedge type blocks | Alan | OpenFOAM Meshing & Mesh Conversion | 0 | July 27, 2009 20:05 |
[Commercial meshers] Tgrid tetra mehs with problems | braennstroem | OpenFOAM Meshing & Mesh Conversion | 2 | June 18, 2007 03:39 |
