[ANSYS Meshing] Pre-tension command for static analysis? |
July 27, 2017, 05:33 |
Marco Sensale
Rep Power: 9 |
Good morning,
I can not find the ANSYS command to set pre-tension before of a static analysis. My model is like a plate (see figure joint). My pre-tension is just an extension, like if the four lateral surfaces are pulled. Then I have to simulate another traction with different boundary conditions. Could you tell me a useful command or procedure? Thank you so much! Marco Sensale |
pre-stress, static structural |
How to implement a sensitivity analysis for certain items | Mason liu | CFX | 10 | August 17, 2017 08:46 |
Flutter analysis of compressor blade | sridharabc228 | CFX | 1 | April 13, 2017 19:10 |
FSI-system coupling: "...same analysis type"? | rjw | CFX | 0 | March 26, 2017 07:25 |
ANSYS WORKBENCH Transfer result of one analysis to a new analysis as preload | ingjuanm90 | ANSYS | 0 | July 26, 2016 14:04 |
How to add Surface Tension in cavitatingFoam solver | jamestangx | OpenFOAM Programming & Development | 1 | April 6, 2016 16:39 |
