[ICEM] how to pick up geometries in ICEM cfd in batch mode?
Old   July 24, 2017, 00:28
Default how to pick up geometries in ICEM cfd in batch mode?
N-S
Andrew
N-S is on a distinguished road
I‘m writing a code to process a parametric model,whose inlet counts may be 2~5.the geometry is imported from UG in *.x_t format,
since the inlet counts are varying, if I want to pick up all the inlets faces and sort them in different parts. Can anyone tell me how to do this in batch mode?
all the points positions is known.
I have tried the "ic_geo_pick_location" ,but it doesn't work well
N-S is offline   Reply With Quote
Old   July 24, 2017, 05:06
Sebastian Engel
bluebase will become famous soon enough
Hi Andrew,
i have used "ic_geo_find_nearest_srf_pnt" succesfully in the past.
"ic_geo_find_nearest_srf_pnt srf.01 pnt.01"
This should also work in batch mode.
With regards,
Sebastian
bluebase is offline   Reply With Quote
Old   July 24, 2017, 23:25
N-S
Andrew
Hi Sebastian,
Thank you for reply,
" ic_geo_find_nearest_crv_pnt" "ic_geo_find_nearest_srf_pnt " finds parameters of closest point on surface, the return is unitized uv/t coordinates.
I want get the surface /curve name.
Fortunately, I find "ic_geo_nearest_surface_list" RIGHT BELOW "ic_geo_find_nearest_crv_pnt crv pnt" in “Programmers Guide”.
many thanks
Andrew
Old   July 25, 2017, 13:36
Sebastian Engel
many thanks
Andrew
Hi Andrew,
i guess i mixed this up in my notes and just copied it here... i'm glad it still helped somewhat =)
with regards,
Sebastian
batch mode
Import Mesh from ICEM CFD to CFX Andre Almeida CFX 16 April 19, 2016 04:42
[ICEM] ICEM CFD error when running in batch mode bgp723 ANSYS Meshing & Geometry 0 August 14, 2014 14:45
Learn ANSYS ICEM CFD easy_astronaut ANSYS 2 December 15, 2013 16:34
Scaling, Rotating-Translating in Icem Cfd KhXeR ANSYS 1 July 5, 2013 05:50
[ICEM] Export unstructured periodic mesh from ICEM CFD to Fluent ivanddd ANSYS Meshing & Geometry 1 February 3, 2011 01:51
