Adam
Rep Power: 9 ![]() |
Hi guys! I have a problem with meshing, I'm trying to follow PEMFC tutorial using ICEM to do meshing - no matter how hard I tried - i was not able to do this with build-on meshing tool. However as you can see I have some weird holes in my mesh, I know it can be fixed using repair geometry tool with marked option 'Split surface at T-connections' but I would like to understand whether it's gonna affect on my results (as I see the channel walls' mesh was signed to the current, where previously both of them had meshed walls - basically it is shown on the last screenshot). According to the tutorial 'Multiple eges' problem is not really important and I shouldn't be bothered by that.
I assume that problem is that this is assembly of 9 parts with lines (edges) and corner points interfering on each other. Last question - isn't something wrong with my mesh quality - it looks way too good (3rd picture). ![]() ![]() ![]() ![]() ![]() |
fluent, holes, icem, meshing, size |
[ANSYS Meshing] Meshing a flat plate with cooling holes with a plenum using Centaur as a Meshing tool | TheStudent | ANSYS Meshing & Geometry | 0 | March 13, 2017 09:58 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
[ICEM] Holes in mesh; Cylinder meshing using hexa | MiloslavDohnal | ANSYS Meshing & Geometry | 1 | February 2, 2014 14:24 |
[GAMBIT] GAMBIT Meshing of Pipe with Holes Perpendiculer to Flow Stream | rocketman1151 | ANSYS Meshing & Geometry | 7 | November 30, 2011 02:39 |
