[GAMBIT] Mesh generating for a flapping foil in RBF method
Old   July 18, 2017, 00:54
Default Mesh generating for a flapping foil in RBF method
Hanye Azimi
ronak is on a distinguished road
Hi there
I hope you are doing well. I'm going to simulate a flapping foil near water surface by openFoam. I mean plunge and pitch motion by flapping. In my case the foil rotates about 90 degree so I have to use RBF method for dynamic mesh, I suppose.
How can I produce a dynamic mesh in RBF method?
Appreciate
ronak is offline   Reply With Quote
Old   July 18, 2017, 02:35
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
the dynamic mesh will be treated in your solver, meaning OF (what RBF stands for?) and I don't know how it works in OF.
In Fluent, years ago, you were able to treat it with 3 methods: layering / remeshing / smoothing.
The mesh in Gambit would have been influenced by the dynamic mesh method, especially for layering.
Now in OF, I have no idea
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   July 18, 2017, 05:26
Default Rbf
Hanye Azimi
RBF is Radial Basis Function. I know it from Frank Bos thesis.you can see Released RBF motion solver
for more detail.
Thanks for information
Best
dynamic mesh, flapping motion, mesh 2d, rbf interpolation
[mesh manipulation] Generating a single cell mesh using a patch of a 3d mesh kebsiali OpenFOAM Meshing & Mesh Conversion 3 May 30, 2016 07:36
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
[ICEM] Problem with using the Delaunay volume mesh method manahara ANSYS Meshing & Geometry 12 December 25, 2014 22:54
ParaView and Qt 4.3.5 on Mac OS X 10.6 Adrian OpenFOAM 3 August 8, 2010 04:16
