[ICEM] New Block resets edge parameters
Old   July 17, 2017, 12:12
Default New Block resets edge parameters
Andy
Starcatcher is on a distinguished road
Hi folks,
I have a special way to work in ICEM with complex geometries. Instead of creating one single block and splitting it I create one block after another according to the geometry needs. Then I determine the edge parameters.
BUT if after the setting of the parameters it becomes necessary to create an additional block with the simple tool [Blocking->create Block] I can observe that each adjusted edge parameter in the whole model gets a reset to the initial state at the moment of its creation (2 Nodes, Bigeometric mesh law,…).
Is there a possibility to create an additional block without influencing other parameters?
Thanks in advance!
Starcatcher is offline   Reply With Quote
block, parameter, reset
[blockMesh] Inconsistent number of faces between block pair 0 and 5 R_21 OpenFOAM Meshing & Mesh Conversion 2 July 13, 2015 13:20
[ICEM] Shifted Periodic topology venkat_aero2007 ANSYS Meshing & Geometry 17 August 27, 2013 02:41
[ICEM] Edge Parameters Question RodriguezFatz ANSYS Meshing & Geometry 5 August 15, 2013 11:13
blockMesh: block with 6 vertexes dani OpenFOAM 3 June 25, 2009 14:13
