[ANSYS Meshing] How to properly mesh whole wind turbine (structured mesh on curved geometries)
Old   July 14, 2017, 20:25
Default How to properly mesh whole wind turbine (structured mesh on curved geometries)
Ruslan
rusham is on a distinguished road
Currently, I'm trying to generate a structured mesh on a wind turbine and encountered some difficulties. As usual, the geometry of wind turbine was designed in Solidworks and imported into Ansys Design modeler (below you can find turbine geometry with enclosure and rotation domain). However, it is difficult to generate a structured mesh on the turbine blade or even proper unstructured mesh. Can anybody help me by answering to below question:
1. Which technique is most appropriate for such kind of study(inside the Ansys): Ansys meshing, ICEM CFD or turbo grid?
2. How is it possible to generate mesh which will not deform geometry with curvatures( turbine blade). Which method to use? How to create rectangular mesh near the turbine blade?
3. Can anybody share the tutorial for such kind of meshing ( I'm going to use Fluent with rotating domain)?
I will be very glad if somebody can help me,
Thank you in advance
rusham is offline   Reply With Quote
Old   July 14, 2017, 22:16
ryariyaz's Avatar
ryariyaz is on a distinguished road
Try slicing to make it sweepable body if possible
Sent from my Redmi Note 4 using CFD Online Forum mobile app
ryariyaz is offline   Reply With Quote
Old   July 16, 2017, 12:03
Ruslan
Thank you for reply,
What do you mean by slicing, can you please specify it. Do you have a tutorial to share?
many thanks
Old   February 16, 2020, 15:29
Nazi
CFD-Shiraz is on a distinguished road
Originally Posted by rusham View Post
Did you solve your problem?
Have you ever tried to mesh the whole turbine (with tower)? If so, what method did you use?
Thank you
CFD-Shiraz is offline   Reply With Quote
[ICEM] 2D hybrid mesh (unstructured mesh highly dependent on structured mesh parameters) shubham jain ANSYS Meshing & Geometry 1 April 10, 2017 06:03
CFD analysis on wind turbine rotor Ken (Wind Turbine CFD Super Rookie) Main CFD Forum 45 February 9, 2016 15:07
[ICEM] 3D Wind turbine mesh luxingzhe ANSYS Meshing & Geometry 16 May 17, 2012 06:40
[ANSYS Meshing] 3d wind turbine mesh for multiphase simulation mingersai ANSYS Meshing & Geometry 0 January 17, 2012 19:20
How to Mesh For Wind Turbine Blades for CFD Simulation in Hypermesh? haristrawberry Main CFD Forum 3 November 12, 2010 07:27
