[BladeModeler] How to set the shroud diameter in Blade Generator |
Rep Power: 14 ![]() |
I don't understand how to set the shroud diameter dimension when I design an AXIAL impeller in Blade Generator. I think that when I design the blade in the meridional window of BG (trace of the leading edge, trace of the trailing edge and so on...) these geometric parameters are all BLADE parameters and affect the geometry of the blade. How can I constrain the shroud geometry (in particular the blade tip/ shroud gap)? In Turbo Grid there's an option which shorten the blade in order to create a gap between the shroud and the blade tip, but this way the blade geometry changes! I need to introduce the gap between the blade tip and the shroud WITHOUT modifying the blade geometry and especially its radial extension. I really hope I have been clear enough to let you understand my problem. Thanks so much for helping me... |
Prakhar
Rep Power: 12 ![]() |
I am facing the same issue, did you find a solution ? Regards Prakhar |
Blade Generator: How to use Design Profile & Trim Profile | Stabum | CFX | 2 | July 31, 2015 13:01 |
How to set composition volatiles and the diameter of particles? | NiBa | FLUENT | 0 | January 26, 2015 13:52 |
correction of Grub after installing Windows XP and 8 | immortality | Lounge | 20 | January 5, 2014 17:41 |
Problem in conducting CFD of analysis of wind turbine blade | atulpat | CFX | 16 | August 17, 2013 04:09 |
Help with GNUPlot | Renato. | Main CFD Forum | 6 | June 6, 2007 19:51 |
