[ICEM] Maximum number of points to make a curve? |
July 8, 2017, 06:59 |
Stuart
Rep Power: 26 |
When making a curve using From Points (help/icm_help/igeom_createcurvefrompts.html), is there a maximum number of points that can be used to make a curve? I'm making a curve of an aerofoil using imported points (https://www.grc.nasa.gov/WWW/wind/va...af/raetaf.html) and starting at the sharp trailing edge after selecting an amount of points ICEM then stops selecting them (it is known when a point is selected as it is circled with a yellow line). After a few tests ICEM is only let me select a maximum of 100 points, how can this be increased? Thanks Last edited by siw; July 8, 2017 at 07:19. Reason: Extra info |
Decomposing meshes | Tobi | OpenFOAM Pre-Processing | 22 | February 24, 2023 10:23 |
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 13:55 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 19:45 |
Diverging solution in transonicMRFDyMFoam | tsalter | OpenFOAM Running, Solving & CFD | 30 | July 7, 2014 07:20 |
[blockMesh] --> foam fatal error: | lillo763 | OpenFOAM Meshing & Mesh Conversion | 0 | March 5, 2014 11:27 |
