[BladeModeler] Blade ExportPoints & Hub/Shroud Offset |
July 7, 2017, 14:10 |
Dim. G
Rep Power: 9 |
Hey guys,
I am using design modeller to import the geometry of a blade from a cad file, then using the flowpath and export points I will export the blade's geometry to a turbogrid format. The problem I am facing is, while I am trying to use the exportpoints, at the blade Surfaces -> Hub/Shroud Offset % the minimum value in my case that I can export the points is around 5%, which I think is a very high number!? So I have two questions: 1) Do I lose the part of the blade where it is below the green loop? (see picture) 2) How can I reduce the offset % Thank you in advance |
July 3, 2018, 13:59 |
VU Tuan-Long
Rep Power: 8 |
I'm also confused between this feature and the hub/shroud offset in turbogrid. Can anyone tell me the difference?
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
[TurboGrid] Slotted rotor Blade using Turbogrid | drcsm | ANSYS Meshing & Geometry | 0 | March 15, 2016 01:26 |
Blade Thickness Distribution w/ Blade Distortion | twolfe13 | Main CFD Forum | 1 | May 22, 2014 01:10 |
Problem in conducting CFD of analysis of wind turbine blade | atulpat | CFX | 16 | August 17, 2013 05:09 |
Compressor Blade Analysis in Ansys CFX | LynchMobster47 | Main CFD Forum | 0 | April 10, 2012 23:43 |
