Meshing fails because of duplicated nodes in boundary mesh
Old   June 30, 2017, 10:35
Default Meshing fails because of duplicated nodes in boundary mesh
arijit bhattacharya
arijitb is on a distinguished road
I got this when meshing in ansys workbench-Patch-conforming tetrahedron mesh failed because of duplicated nodes in boundary mesh. Can anyone help about why I am getting this error and how to bypass it?
arijitb is offline   Reply With Quote
Old   August 20, 2017, 04:49
majid fahim
majid fahim is on a distinguished road
I have the same problem when I try to mesh an enclosure of a horizontal axis wind turbine
When I click show problematic geometry it gives me a node at the boundary of the inlet of my cylindrical enclosure
Can anyone help
majid fahim is offline   Reply With Quote
Old   August 20, 2017, 05:41
majid fahim
Try decreasing max face size in the sizing function
That solved the problem for me
Old   April 30, 2021, 01:53
Default Patch-conforming tetrahedron mesh failed because of duplicated faces in boundary mesh
Siti Aishah
Siti Aishah is on a distinguished road
Hi. I have tried to mesh a propeller in a rotating domain. I have this problem where the mesh failed because of the duplicated faces in the boundary mesh. I have mesh the single propeller without the domain and it succeed. But when I mesh together with the domain, I got this error. Can somebody help me with this?
I have attached the propeller file and propeller with rotating file in igs format.
Siti Aishah is offline   Reply With Quote
Old   April 30, 2021, 16:32
Kira
aero_head is on a distinguished road
You should start a new thread instead of posting on an old one.
aero_head is offline   Reply With Quote
icem 14.5, meshing 3d, patch conforming, tetrahedral mesh, workbench 14.5
y+ = 1 boundary layer mesh with snappyHexMesh Arzed23 OpenFOAM Running, Solving & CFD 6 November 23, 2022 16:15
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field xiexing CFX 3 March 29, 2017 11:00
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
