[ICEM] Mesh Independence study
Old   June 27, 2017, 13:45
Default Mesh Independence study
Carlos Modesto
Carlos Modesto is on a distinguished road
Hello everyone.
I'm here to ask a question i got when starting to perform a "Mesh independence study" and probably will have too at "time-step independence".
The deal is, i have read all treads here and a few links over internet about the mesh independence study, and i'm not really clear if the study has to be performed as the simulation where going to be performed or if i can make a simple simulation just to perform the study. My main simulation goes around 3-4 days in a 800,000 elements grid, so i would like to avoid this by doing a simple simulation on the study.
Thanks in advance for yout attention
Carlos Modesto is offline   Reply With Quote
Old   July 4, 2017, 14:22
f.yn is on a distinguished road
hi
what kinds of simplification do you want to perform?
for example you can change it to a steady state problem for mesh study
f.yn is offline   Reply With Quote
Old   July 4, 2017, 14:55
Carlos Modesto
Hi f.yn
Thats was one of the things that i thought or the other one is to avoid the non-newtonian models and run it as a newtonian.
Old   July 6, 2017, 14:51
i'm not sure about that
but i asked someone and he said it won't be a good idea
Old   July 7, 2017, 07:57
Sebastian Engel
bluebase will become famous soon enough
Hi Carlos,
i suggest to not simplify your physics for mesh dependency study.
When you can't go finer with your mesh, then go the other way. Produce coarser meshes and test it against your finest mesh. This is not different than just going finer.
That way you still get an estimate of the mesh dependency of your solution.
bluebase is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
(New to CFD) How to do a mesh refinement study w/ Fluent? JAviles FLUENT 3 June 27, 2014 14:55
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
