[ICEM] ICEM auto meshing,Fluent cannot converged
Old   June 27, 2017, 03:14
Question ICEM auto meshing,Fluent cannot converged
Jimmy Lee
jimmy871013 is on a distinguished road
Dear All:
Hello!
Now, I have another problem which I have struggled couple of days.I think maybe someone can give me some advise.
My rpl file let ICEM meshing my file(unstructured) and the mesh quality check is at least 0.35(some books said it is enough to calculate ). when I input my mesh file into fluent(standard k-e model). The calculation cannot converged: the curve of continuity cannot blew 0.0001.And the curve(continuity and k-energy) always shocking between 0.01 to 0.001. The strange situation is : when I use gridgen(old meshing software),even my mesh quality is 0.1 , the calculation in fluent can converged in almost 1000 steps.
I just wandering why the better quality mesh cannot give me better result. In ICEM:1. I open tin file 2. I check the geometry. 3. I set the global mesh setup (set smooth mesh )4. I set part mesh setup(one part need more mesh)5. I let ICEM meshing 6. I check the quality(at least 0.35)7. i set output(Fluent solver) 8. input mesh file into fluent to calculation.
So do you think the unsuccessful calculation is because my ICEM mesh or maybe is because of my fluent setup? Or maybe is because of unstructured mesh? If I want to use structured mesh can I use rpl file to let ICEM meshing?
Or maybe you have your own opinion in my problem,please let me know your ideas~~Thank you~~
Jimmy
jimmy871013 is offline   Reply With Quote
PEM Fuel cell module meshes. ICEM vs workbench aarvay FLUENT 24 March 2, 2020 07:50
[ICEM] Cannot update new.3dm file in ICEM based on rpl file jimmy871013 ANSYS Meshing & Geometry 3 June 20, 2017 12:02
Cannot update new.3dm file in ICEM based on rpl file jimmy871013 Mesh Generation & Pre-Processing 1 June 20, 2017 03:21
[ANSYS Meshing] Workbench 13: Structured Hexa Meshes rooftop ANSYS Meshing & Geometry 19 March 31, 2016 03:33
re: ICEM vs. ICEM WB Wooster CFX 4 October 15, 2007 13:47
