June 23, 2017, 13:10 |
Hybrid Mesh Interface Node Matching
Abhimanyu
Rep Power: 12 |
Hey Guys,
I am performing URANS 3D simulations of wings using a hybrid mesh methodology with a structured near-field region (hex mesh blocking) and an unstructured far-field region (tetrahedral) , as shown in the pics below. I generate the two meshes in independent projects and import the two mesh files in FLUENT and define the common interface and run the simulation. Now the nodes at the interface don't match, which is not causing an issue in the solution except when I look at the vorticity contours. # Is there a way to make the two meshes conformal in ICEM itself? I tried merging the two meshes in ICEM by importing them and using the Merge Mesh option but it throws up an error as the cell size differs at the interface between the surface triangles and quads due to the impression of the leading edge and trailing edge cell densities on the interface surface. |
June 27, 2017, 00:08 |
Abhimanyu
Rep Power: 12 |
bump post bump post
hybrid grid, icem 17, mesh and fluent, structured grid, unstructured grid |
[ICEM] Error in mesh writing | helios | ANSYS Meshing & Geometry | 21 | August 19, 2021 14:18 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 11:19 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
