[ICEM] ICEM Meshing troubles
Old   June 22, 2017, 18:14
Default ICEM Meshing troubles
kevin dupont
kdupont is on a distinguished road
Hello everyone,
I am new user of ICEM. I want to study for my master thesis the way the fluid behaviours with a change of section (shown in geometry.png). The fluid is going through the left side and is divided between two channels.
I have done my 2D geometry on ICEM, shown in geometryicem.png . I am locked since many nights now on the block definition in a way to do the meshing. I have tried to follow the meshing tutorial (and especially the ANSYS ICEM CFD tutorial "Hexa Mesh Generation for a 2D Pipe Junction"). I have tried by many ways to split edges and the blockd to obtain the same number of edges that I have curves, not to cross the internal edges done in the blocks,but I always obtain the same kind of results shown on metrouble.png . The mesh seems to be crossing and the mesh is never coming red.
Is my geometry wrongly created? Is there a simple way to obtain a nice mesh using ICEM regards this geometry?
All you advices and helps will help me going on.
Thank a lot for your time,
Kevin
kdupont is offline   Reply With Quote
Old   June 23, 2017, 05:00
Sebastian Engel
bluebase will become famous soon enough
Hi Kevin,
can you make some more screen shots of the y bend region? It seems there are some associations wrong; maybe also something with the blocking, but that's not visible in the present screenshots.
I would propose a blocking with the following structure in the y-bend:
with regards,
Sebastian
bluebase is offline   Reply With Quote
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 11:49
Meshing a Mixing Plane in ICEM Will Anderson ANSYS Meshing & Geometry 2 November 9, 2010 10:16
Meshing a Mixing Plane using ICEM Will Anderson FLUENT 0 November 6, 2010 18:08
[ICEM] ICEM meshing problem xyq102296 ANSYS Meshing & Geometry 6 October 28, 2010 11:09
ICEM meshing question gsbhatia89 ANSYS Meshing & Geometry 5 June 14, 2010 09:24
