[TurboGrid] Making a custom topology for Turbogrid ATM |
June 21, 2017, 10:40 |
Rep Power: 9 |
I want to generate a mesh for CFX of an axial turbine where the blades alternate between two different shapes. I.e. one blade of the one shape, then one of the other and one of the first and so on. Please believe me that I have a good reason to do this. My question concerns Turbogrid. When activating the advanced features in Turbogrid, there is the option to make topologies other than the ones in the drop-down menu (single round round symmetric, and so on) from templates. Ansys tells us that these are loaded in from the working directory and the Turbogrid directory, and in C:\Program Files\ANSYS Inc\v180\TurboGrid\etc\templates there are a bunch of files that apparently control how Turbogrid generates topology. They are ascii files, but the syntax is not exactly self-explanatory. Is there any documentation anywhere on how to create and modify these files in a way that could help me solve my problem? I would like to have a topology that is exactly like two different "single round round symmetric" topologies next to each other. I have tried other methods, like traditional in Turbogrid, but due to high turning, the results are not acceptable. Right now my method is to generate two topologies with a gap in between and fill it with an "adapter"-domain. |
February 25, 2023, 19:44 |
Rep Power: 9 |
I contacted Ansys support, and at least at the time, there was no way to specify a custom topology. Some UI elements hint that it may be possible, but afaik, it was never implemented.
topology |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
[Other] How to use finite area method in official OpenFOAM 2.2.0? | Detian Liu | OpenFOAM Meshing & Mesh Conversion | 4 | November 3, 2015 03:04 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
Problem compiling a custom Lagrangian library | brbbhatti | OpenFOAM Programming & Development | 2 | July 7, 2014 11:32 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
