[ANSYS Meshing] How to change element type in Ansys Workbench
Old   June 21, 2017, 08:46
Default How to change element type in Ansys Workbench
Prasanna
vpvmech is on a distinguished road
I need to change the element type as solid 95 in ansys workbench to mesh my model. For that I browsed and identified that it is possible through the insertion of commands. I inserted a command line as ET,1,solid 95 in the command, just below the part in pre-processing section. It showed green color tick. When I meshed, the command I inserted is not executed. If someone gives a proper information on how to change the element type from default selection in workbench through command or some other means, it will be very much helpful to me.
Thanks
vpvmech is offline   Reply With Quote
Old   April 5, 2018, 10:05
Justin Antony
Justin1992 is on a distinguished road
Hi vpvmech.
Did you find the solution. I am also stuck in the same place. I need to add solid 5 and solid45 to my model.
Could you explain how to do it.
With regards
Justin
Justin1992 is offline   Reply With Quote
Old   April 6, 2018, 11:46
Pepino is on a distinguished road
right click on the body you want to change element type under the geometry tree, insert command "et,matid,solid45" or "et,matid,solid5"
it should work.
Pepino is offline   Reply With Quote
command in workbench, element selection, workbench ansys 15, workbench mesh
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) Aadhavan OpenFOAM Meshing & Mesh Conversion 2 March 8, 2018 02:47
LES supersonic free jet martyn88 OpenFOAM 22 April 17, 2015 07:00
Strange high velocity in centrifugal pump simulation huangxianbei OpenFOAM Running, Solving & CFD 26 August 15, 2014 03:27
SimpleFoam - instable simulation Specialist OpenFOAM Running, Solving & CFD 17 August 12, 2014 05:52
Need help with boundary conditions: open to atmosphere Wolle OpenFOAM 2 April 11, 2011 08:32
