[ANSYS Meshing] Geometry limitation cause meshing to fail |
June 14, 2017, 10:12 |
Rep Power: 9 |
I'm simulating a fluid flowing through obstacles in a pipe (for better understanding, have a look at the 2nd picture). As shown in the 1st picture, the edges of the obstacles actually 'pop' out of the pipe. The diameter of both the pipe and obstacles are the same. In real application, the obstacles are actually conducting heat from the wall of the pipe. Is it possible to force the meshing without introducing a gap between the obstacles and the pipe (so that the heat conduction can be retained)?
Dynamic Meshing of Simple 2D Geometry | harman79 | FLUENT | 2 | January 17, 2018 07:07 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 11:49 |
Gambit meshing problem to following geometry | ahmadmln | ANSYS Meshing & Geometry | 2 | October 21, 2014 02:49 |
[ANSYS Meshing] Using more than one meshing method on a single 2D geometry | robbierich90 | ANSYS Meshing & Geometry | 0 | October 30, 2011 14:12 |
Need help on meshing this simple geometry | nha1g08 | ANSYS Meshing & Geometry | 3 | March 9, 2011 03:13 |
