[ICEM] Bad mesh with strong curvature in ICEM |
May 31, 2017, 23:27 |
Andrew
Rep Power: 11 |
I have been using ANSYS ICEM for the past couple of years but there is a mesh problem that I have been unable to find a solution to. I'm using a block based mesh to mesh a centrifugal compressor. With a coarse mesh, I generated a fairly good quality mesh. But, when I increase mesh density, there is bad mesh at the surface of the blade where there is strong curvature. Looking pre-mesh quality and mesh slice (attached images) it appears that the mesh at the surface is going into the wall and is not orthogonal. I have tried many different options, but nothing appears to fix the problem. Is there an option get the mesh to respect the surface of the geometry and be orthogonal? Thank you, Andrew |
June 6, 2017, 10:01 |
Rep Power: 12 |
icem 15, meshing |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
Parametric Mesh with ICEM and Workbench fails to update | fabian.schicker | ANSYS | 0 | May 9, 2017 08:20 |
ICEM of ANSYS V15: how to export .msh mesh for CFX | hydroaero | ANSYS | 1 | March 9, 2015 22:17 |
[ICEM] Generating mesh for modified parts in ICEM without changing mesh of other parts | a.habibi | ANSYS Meshing & Geometry | 5 | October 4, 2012 05:10 |
Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 14, 2003 23:19 |
