[DesignModeler] Triangular (or sinusoidal) wall drawing in ANSYS dm |
May 28, 2017, 07:18 |
Seyma
I have to draw triangular or sinusoidal wall in Ansys dm and their amplitude and phase angle (for sinusoidal) are defined. I have searched about sinusoidal case but it should be drawn in the Solidworks and imported to Ansys. Is there any other option to create this? If there is no possibility to draw sinusoidal wall I should draw triangular one so all information and hints will be helpful for both cases. Thank you in advance. |
a sinusoidal force added to the wall of combustion chamber | zhichaozhao | FLUENT | 1 | August 24, 2016 09:09 |
UDF for Sinusoidal wave propagation at channel wall | engrmansoor2534 | Fluent UDF and Scheme Programming | 5 | August 21, 2015 05:01 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
Wall Motion Based on Shear Stress in ANSYS CFX | saeedmech | CFX | 1 | October 19, 2014 06:15 |
Problem in IMPORT of ICEM input file in FLUENT | csvirume | FLUENT | 2 | September 9, 2009 02:08 |
