May 16, 2017, 07:27 |
problem in structured mesh
sanatan choudhury
I am trying to generate a mesh which consists a block with v-notch and a hollow cylinder above it, whose bottom surface is absent so that a fluid drop can pass from the inside of the cylinder to the notch cavity (fig. capture17). But I am facing the below problems
1. I am unable to give the bottom surface as interior (shows error in fluent). 2. if I am not keeping any bottom surface of cylinder the mesh becomes something else (fig.s attached in the drive). I have shared you the geometry file also in the drive folder.https://drive.google.com/drive/folde...lE?usp=sharing |
icem, mesh, structured |
problem with structured map mesh in gambit. | mk091088 | ANSYS Meshing & Geometry | 0 | October 30, 2016 19:24 |
[ICEM] Problems with structured mesh in IcemCFD symmetric problem | jexposito | ANSYS Meshing & Geometry | 3 | December 19, 2015 05:34 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
[ICEM] Problem making structural mesh on a surface | froztbear | ANSYS Meshing & Geometry | 1 | November 10, 2011 08:52 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
