May 14, 2017, 02:02 |
Issue with merging meshes
Prem Sagar
Rep Power: 9 |
Hi!
I wanted to mesh an interior part of my domain. Since I wanted non conformal mesh, I figured I'll create sub-topologies and merge two different hexahedral meshes. I have attached the pictures for reference. I ran the mesh check and I was able to fix uncovered faces. But new problems arised: 1. Multiple edges 2. Non-manifold vertices 3. Penetrating elements I couldn't quite figure out how to deal with these. The 'fix' option I encountered on the fly didn't seem to work because they popped up again the second time I run the mesh check. So what can I do to avoid these issues? Thanks in advance! |
June 19, 2020, 08:26 |
Rep Power: 6 |
Hi,did you solve it? I also have the same problem
icem 16.2, mesh merge, multiple edges, non manifold vertices |
bad momentum source, vortice direction with twoPhaseEulerFoam and non-ortho meshes | cutter | OpenFOAM Running, Solving & CFD | 7 | November 17, 2016 14:17 |
scalarTransportFoam issue with dynamic meshes | Thangam | OpenFOAM Programming & Development | 5 | August 18, 2015 15:52 |
[Other] Can't import airfoil meshes successfully | klausb | OpenFOAM Meshing & Mesh Conversion | 7 | May 26, 2015 15:51 |
Meshing related issue in Flow EFD | appu | FloEFD, FloWorks & FloTHERM | 1 | May 22, 2011 08:27 |
Large 3D tetrahedral meshes | Aldo Bonfiglioli | Main CFD Forum | 4 | August 27, 1999 03:33 |
