[ANSYS Meshing] Instance Meshing with Shared Topology
Old   May 12, 2017, 06:13
Default Instance Meshing with Shared Topology
hunger is on a distinguished road
Hi everyone!
I want to model combustion in a chamber with 10 burners. These burners have exactly the same geometry, so I would like to use "Instance Meshing" to copy the mesh from one burner to the others.
Unfortunately Instance Meshing is not available when "Shared Topology" is enabled (which is necessary because I have got a multibody geometry and I want to create a conformal mesh for my Fluent simulation).
My geometrical pattern of the burners is produced using Space Claim Direct Modeler.
Does a switch to the DesignModeler solve this problem (I have read that it should be possible with the "Automatic" option for shared topology)?
Any help is very much appreciated!
P.S.: I am using Ansys R180.
Best regards,
Harald
hunger is offline   Reply With Quote
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 08:56
Meshing topology for heat transfer over ribs Far Main CFD Forum 14 November 8, 2013 01:08
Shared surface between bodies for better meshing? alxe ANSYS Meshing & Geometry 5 August 18, 2011 12:52
Volume 1 has invalid topology for mapped brick meshing georgewar ANSYS 0 July 24, 2011 17:02
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 12:09
