May 6, 2017, 14:53 |
Poor Quality Sweep Meshes
Rep Power: 10 |
Program: ANSYS Meshing 16.2
Issue: Mesh quality is poor when meshing a simple volume, sometimes. The Good Mesh and the Poor Mesh are using the same settings (see image) and I have tried meshing with each suppressed while meshing the other, but get the same results. Both volumes are simple cubes. The Poor Mesh wants to taper to a wedge for some reason which is the area of poor mesh. I can not figure out why two similar geometries are meshing completely different. I have tried sizing methods for edges/faces on the Poor Mesh but can not get rid of the wedges. I have also tried to search the forum but I can't find a similar issue. Any help is greatly appreciated, thanks! |
May 12, 2017, 04:43 |
Paweł
Rep Power: 10 |
Using Hard Behavior on edge sizing might solve the problem.
If the leftmost edge is slightly longer then using element size may result in one additional division at that edge, casuing wedges to generate. In that case it is better to use equal number of divisions at each vertical edge. |
May 12, 2017, 16:10 |
Rep Power: 10 |
The problem was that the volumes were slightly offset (0.00001 ft) and fixing that resolved the issue. I had tried the hard behavior but since it was Shared Topology, the issue persisted. But thanks for the input!
meshing, quality, sweep mesh |
Mapping (interpolation) between two meshes | Ebrahim | OpenFOAM Programming & Development | 2 | June 15, 2020 13:31 |
How can I put the data of adpated meshes on the original unadapted meshes? | xh110120 | FLUENT | 2 | March 11, 2016 02:00 |
[GAMBIT] Skewed meshes in meshing of hydrocyclone | Iman Sengupta | ANSYS Meshing & Geometry | 7 | June 3, 2015 07:57 |
Hex and Tet meshes - simplefoam comparison | danvica | OpenFOAM Running, Solving & CFD | 10 | January 4, 2013 01:18 |
[ICEM] Icem 12.1, O-grid - sweep combination | pertupd | ANSYS Meshing & Geometry | 1 | June 18, 2010 14:00 |
