[ANSYS Meshing] 3D Inflation mesh on an airfoil
Old   April 26, 2017, 04:04
Default 3D Inflation mesh on an airfoil
Ken
kennyboy is on a distinguished road
Hi there!
I used ANSYS mesher to create a mesh for the control volume occupied by the airfoil.
I have a problem with the inflation layer on the airfoil surface.
Initially, the inflation layers at the tip of the airfoil has high skewness. So I solved it by creating a plane and cut the 3D airfoil at the sharp edge, then further extending the inflation layers at the sharp edge to the wake region of the airfoil. Hence, the inflation layers do not high skewness at the sharp edge.
However, by cutting the airfoil into two halves and creating an inflation layer in the wake region of the tail, the inflation layer at the head of the airfoil now has high skewness.
So anyone has any advice on how to solve this high skewness at the edge? Or better solution to create inflation layers across the airfoil of good quality?
Thank you!
kennyboy is offline   Reply With Quote
Old   April 26, 2017, 04:12
Ken
This is a screenshot of my mesh when I create inflation layers at the airfoil surface ONLY
This is a screenshot of my mesh after I extended the inflation layers into the wake region of the airfoil. (Purpose of this extension is to reduce the skewness of the meshes at the tail)
ansys, boundary layer, inflation later, mesh, mesher
[ANSYS Meshing] Problem with Inflation Descreasing Mesh Quality wildan ANSYS Meshing & Geometry 20 March 4, 2019 04:29
High drag for airfoil compared to XFOIL and wind tunnel data Ry10 SU2 15 October 30, 2016 18:27
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 05:24
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
